1994 Chateau want start after trailer plug replaced
Old 03-22-2015, 05:38 PM
hellodon's Avatar
hellodon
hellodon is offline
Smile 1994 Chateau want start after trailer plug replaced
Good evening
I have a 1994 Chateau e150. Took it to have the 4 way Trailer plug replaced. Van wouldn't start again afterwards. It turns over, I have fuel pressure - and spark going to the coil on the negative side, spark at the plug. Any chance cutting the wires at the 4 way plug ( I think they left the ignition on) kicked in the antitheft? Tried locking and unlocking the door to disable cut off, no change. It looked like based on what I read that fuses 6 and 12 control the module, took those out, no change.
I have never had a problem previously with this vehicle starting... could be a coincidence that it happened after working on the wiring but it doesn't seem so in my opinion.
FYI - the alarm went off twice on it (earlier in the day before the trailer plug work) after locking the vehicle. Had to leave it unlocked. Drove and started it several times after that with no ill effect.
Any ideas?
Thanks, Don
Old 03-22-2015, 08:29 PM
tabijan's Avatar
tabijan
tabijan is online now
If you have fuel and spark, any immobilization feature isn't the problem. Spark is obvious to see so I'd recheck fuel at the cylinders.
Sixto
93 E150 Chateau 5.8 190K miles
Old 03-23-2015, 09:38 AM
hellodon's Avatar
hellodon
hellodon is offline
I will check that next - thanks for the help
ladlehead
06-13-2019 07:26 AM
Steven Adermann
04-30-2016 08:47 AM
Ford F1Fool
1997 - 2003 F150
04-18-2010 05:31 PM
solopony7
2004 - 2008 F150
12-08-2008 07:03 PM
fyrhog
1999 to 2016 Super Duty
09-12-2005 08:42 PM
Quick Reply: 1994 Chateau want start after trailer plug replaced
