Turbo keeps blowing hoses off
I just recently repaired issues with my 6.0 and now new issues has begun. The turbo keeps blowing the pipes out of the rubber hoses. Not sure what is happening or why so a little insight would be helpful.
Oh yeah out of all the work completed in my previous post..don't bother replacing the solenoid section of the injectors. I replaced two the bad ones, rebuilt the other 6 with new everything including a cleaning and now I am getting codes for 3 that are going bad. Oh well I tried right...
Thanks
Joe
Thanks
Joe
Instead of 9ft/lbs i torqued mine as tight as i possibly could with a 1/4 ratchet. Was sick of them blowing off as well, you would need a breaker/cheater bar on those clamps to taper those CAC pipes. Make sure you clean the surface well, and clean the hose mating surface and then reel that sucker down. My biggest culprit was the hot side right off the turbo, was many a time when i would step on it and almost give the fiance a heart attack when it blew off
In addition to the already mentioned items, I was able to fasten 2 clamps on the metal tube at the intercooler entrance location. At the turbo compressor outlet i also installed lock nuts against the nylock nuts that are on the clamps. I found that mine loosened until i put on the lock nuts.
Also, i think my open air CCV keeps that oil mist to a minimum inside the tubes.
The dent is a right of passage, you can't be a 6.0 fanatic without a dented hood.
Mine wouldn't stay on either, they were oil soaked so I replaced them, problem resolved.
YEAH, the hood is the only part I see while driving and it would drive me crazy to be looking at a dent the entire time I'm driving. I've got a rock 'star' on my windshield right near the wiper and (thankfully) I don't notice it.. but I do need to get it fixed... glad this thread reminded me of it.
Maybe it is time to remove the CAC itself and upend it and see how much oil comes out.
We found many in the fleet that had long standing high crank case pressure that oil had parially filled the cac. Had to drain them and flush/boil them out.
The inlet and outlet are above the bottom of the cooler. In our case some of them had over a pint of oil come out.
