1966 F100 Radiator Recommendation
Old 03-13-2015, 12:12 PM
Mercmeister's Avatar
Mercmeister
Mercmeister is offline
Hi -
I need to replace the radiator in my 1966 Ford F100 pick-up and would like some good recommendations on what/where to buy. My truck originally had a 352 V-8 with a factory automatic transmission, but now has a 360 V-8 with a C-6 automatic transmission. The previous owner installed a radiator without the transmission cooler reservoir and simply jumpered the supply and return lines to the tranny. This truck is just a daily driver in Nebraska and might ocassionally pull a small pop-up camper. I am willing to give an aluminum radiator a try, but am looking for any pros/cons with going aluminum.
Any recommendations will be greatly appreciated!
Thank You,
Dan M.
Old 03-13-2015, 12:48 PM
banjopicker66's Avatar
banjopicker66
banjopicker66 is offline
In terms of thermal conductivity, copper is almost twice as conductive as aluminum - but the construction of today's radiators makes aluminum ones just as or almost nearly as efficient.
But copper will set you back a bunch more, too.
In my opinion, the debate of copper versus aluminum boils down to cost advantage over that of metallurgy.
I replaced my original one with an aluminum one from the local parts store and it bolted right up. Ask for one for a '73-'76 F-150 with a 390 and automatic.
The only alteration you may need to make will be in the outlets of your radiator hoses. My new radiator came with a sleeve for the upper hose, as my original upper hose was larger than the new radiator's upper inlet.
Hope this helps.
Old 03-13-2015, 01:08 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
If the original can be recored or "rodded out" or brazed to make a solid, lasting repair that's the way to go I think. That's not always the case, but if so the cost will be economical (depending on location) compared to a new radiator, aluminum or otherwise.
Old 03-27-2015, 12:36 PM
millerdude's Avatar
millerdude
millerdude is offline
With aluminum ya gotta be careful with the water and grounding issues; I think the word was Electrolysis. The block has to be cleaned out and flushed, and replaced with distilled water...there are some issues. A copper one you can just replace, or repair your old as was suggested. I was about to spend the money on aluminum, but went with a new copper unit and a clutch fan from a newer model F350 with the correct water pump rotation. Will build a shroud later to match up to my 460.
Old 03-27-2015, 12:52 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1966 F100/250 2WD & 1967/79 F100/350 V8 radiators will interchange, but there are TWO different types used 1967/79.
The Super Cooling radiator uses a different radiator support than the standard/xtra cooling and A/C radiators, as it has with a larger opening radius.
pseudo7263
07-14-2017 07:23 PM
FordStolz68
21
05-30-2015 05:12 PM
Schuey
19
11-16-2014 01:10 PM
CropDusterMan
11-04-2012 04:48 PM
fettless
11-23-2010 09:55 AM
Quick Reply: 1966 F100 Radiator Recommendation
