Best truck for towing 16k?
So I have this 16k pound gooseneck dump trailer. I'm wanting a 10k truck to tow it with. I'm thinking a dually, but doesn't have to be. I won't be using it but a couple times a month, so I don't want to spend a boat load of $$$. I'm not worried about going fast, just getting there safe. So what engine (probably gas in my price range), transmission (auto or manual), and what rear gear ratio is best. I'm not new to towing or big rigs, but I thought I'd ask what to look for and what to run from. Thanks!
Google search: for example: 2007 F350 towing. Choose the one that has Fleet Homepage | fleet.ford.com in the results. Works for any of the newer years. I'm guessing a 2005 or later with that weight. I had a V10, I wouldn't want to pull that much weight with one.
I actually don't want to spend much money at all. I'm not afraid of an older truck with a 460 or 351 (although I question it's power pulling 23k total). I question the power of a 7.3 IDI or a 6.9 though. There are several around in the $3k to $4k range in great shape, but I don't know if they'll be enough to pull that much weight. Thoughts?
I can just go by experience. I had a 1999 F250 with a V10 and a 4.10 rear. I pulled a 12k lb 5th wheel with it and it was always a struggle. What will be the pin weight of your trailer? It will probably be too much for any of the older single wheel trucks so you probably need a dually. Just for reference, my 2004 in the signature is only rated at 20,000 GCWR. With your 16K trailer it would be 4k over that limit. It's only rated at pulling 12k. In 2005, the F350 was increased to 23,500 GCVWR. So even at that you would be close. I think it was rated at towing 15,600. If you find a Ford you are interested in just use that google search. Make sure you look at the exact year, model, gearing, and configuration when you look at the chart because Ford is pretty specific with their listing.
Sent from my Telegraph using IB AutoGroup
My 2004 DRW with the V-10 is only rated to pull less than 11K because of the 4.10 rear.
That would be a hairy ride with 16K in tow.
I've never towed with any dually newer than my '04.
I would imagine the brakes on a '08 are much better than what came on my '04.
I live by the 80% rule.
I'm more comfortable at 80% of the rated capacity of things.
( air pressures, load capacities, etc.
clueless101
1999 to 2016 Super Duty
35
04-16-2018 10:07 AM
