49 F1 Door Striker Question
I'm nearing completion of my 49 F1 rebuild. I bought new door strikers and I notice now that there is a small vertical ridge between the two 12-24 mounting cage nuts, Is there supposed to be some sort of pad that goes between the striker and the post? Seems to me that there must be as the striker will not sit flat any other way. I don;t see one offered in any catalog, but I suppose I could easily fabricate one from gasket material
Thanks Bill
Thanks Bill
I'm talking about the wedge shaped piece that attaches to the door post, which the spring loaded door piece latches onto. Here is a picture of my door post. As you can see there is a definite vertical ridge, about 1/8" in height between the two 12-24 striker attachment machine screw holes. Something must go in here otherwise the striker plate would rock--either that or the Chinese replacements are not factory correct!
Bill
Bill
Thanks for the info. I think I'll see how the door latch clears the striker once I hang the doors, then I'll be able to decide whether to add shims or grind off the ridge. Seems there must have been some shim or a groove on the bottom of the striker otherwise you couldnt adjust the striker in and out as you're supposed to be able to do.
Bill
Bill
Ah, yes, the elusive backside ridge. My '49 F4 has the door jam ridge and I thought I remembered the grooves on the back side of the latch. I could not find the original latches but the replacement latches have hash marks that probably serve to grip with the raised ridge on the door assembly.
lm987
05-25-2013 12:23 PM
