Swapped my bench for buckets in my 99XL
Old 03-07-2015, 10:50 AM
F91's Avatar
F91
F91 is offline
Swapped my bench out for cloth buckets from a 2000 Expedition . The drivers side is power so I ran wires to the
passenger side kick panel passenger side kick panel
. Works great. The only thing I would mention is that the 2 rear inboard holes that land the seat belts and a bigger bolt than the others. Make sure when you get your source seats to grab those bolts and a couple extras for the front . Fit and works perfectly.
Old 03-07-2015, 03:04 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is online now
there are always a lot of question on this forum of "will these seats fit my truck"... I have a feeling that FORD used a standard bolt pattern and NORMALLY all seats would be interchangeable. Like you said, small changes to the bolts, spare holes or seat belts might occure....... I had very similar seats in my 2001 CREW - but with arm rest in thee middle.. Nice seats !
Old 03-07-2015, 08:25 PM
F91's Avatar
F91
F91 is offline
I had to tap the forward inner holes for the seats as Ford has holes there, but they aren't threaded. The seat belt wiring plug was a direct match but I had to splice my power and ground directly into the power seat wiring harness. went ahead and wired an inline 30 amp fuse there too, just in case.
Old 03-08-2015, 03:45 PM
NFLD FLARESIDE's Avatar
NFLD FLARESIDE
NFLD FLARESIDE is offline
Awesome. Nice manual trans haha
Old 03-09-2015, 05:05 PM
F91's Avatar
F91
F91 is offline
Way too gun shy about a used auto 4wd. Too many horror stories.
Old 03-09-2015, 07:03 PM
Kellyblues's Avatar
Kellyblues
Kellyblues is offline
Good idea and well done. I've been thinking of doing the same thing with my 99 XLT because I don't like the arm rest and I loath the drink holder. Its not forward near enough. Part of that is I position myself closer to the wheel than most people even though I'm 6'1. The closer you are to the controls of the vehicle the more control you will have. The arm rest and drink holder should adjust to fit driver comfort IMO.
Old 03-09-2015, 07:24 PM
kd4gij's Avatar
kd4gij
kd4gij is offline
I did the same thing in my 99 xl
Old 03-10-2015, 06:39 AM
F91's Avatar
F91
F91 is offline
If your truck is an auto, grab the Expedition center console too, fits perfect. Don't forget the mounting bracket
Old 03-11-2015, 11:41 AM
F91's Avatar
F91
F91 is offline
I tracked down a center console from a 97 at a local wrecking yard. Hope to have it installed by Friday.
Old 03-12-2015, 05:58 AM
Kellyblues's Avatar
Kellyblues
Going on a quest this weekend hopefully I get lucky.
Old 03-12-2015, 02:51 PM
F91's Avatar
F91
F91 is offline
Started on my console yesterday. Gotta tap 4 factory holes
Old 03-12-2015, 02:53 PM
F91's Avatar
F91
F91 is offline
Inner housing-
Old 03-14-2015, 07:05 AM
F91's Avatar
F91
F91 is offline
Just a heads up. The factory holes that are for the rear of the console are bigger holes than the front. I tapped the rears at 12-1.75 and the fronts at 10-1.50. I thought it was odd that they had different sized holes. Console is all installed now. If you have the chance, put it in before the seats. Much easier that way.
Old 03-14-2015, 07:20 AM
kd4gij's Avatar
kd4gij
kd4gij is offline
Where the pic of completed.
Old 03-14-2015, 07:23 AM
F91's Avatar
F91
F91 is offline
I'll post a few pics later today
Quick Reply: Swapped my bench for buckets in my 99XL
