Vacuum lines sections missing_need info how they connected
Old 03-06-2015, 01:30 PM
PEG's Avatar
PEG
PEG is offline
Edited Mar 6.
Rats / squirrel apparently chewed some of the vacuum lines on top of engine (see pics).
** Most important, where does the white "mini" line go, once it disappears - down - between engine & firewall (item #3 in pic) - on passenger side?
** If I can't find where the white line goes (to LEFT side of image), all bets are off.
I can't see that it continues (at all), once it makes the turn down - between engine & firewall. Nor find a loose end under the truck.
In the 1st pic, you see the sheathing (black) around the white line, where it goes to the left of pic, then turns down between engine & FW.
When I gently pulled that section, there was only 6 - 8" of the white line (inside the sheathing) that went behind the engine.
The sheathing also stops - a few inches after it runs down - between engine & FW. From underneath, I can see the end of sheathing - between engine & FW, but not anything under there w/ the broken end still attached.
Possibly? that white line (& sheathing) didn't originally go down between the engine & FW? If it went somewhere on top, then broke, then fell down the back of engine, I can't find the other end attached to anything on engine's top side.
The vacuum line diagram pic I added, mentions a "vent."
1) Need to know how exactly they connected, if a TEE(s) was there (now missing)?
2) How the white vac line's 3 loose ends all connected?
3) [Edit: Answered: they do have barbs.] If this vacuum line has "special" ends - where shown fitting into the 3 - hole rubber tube, attached to air intake (point # 2 in pic).
Thanks.
Old 03-08-2015, 10:30 AM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
you might try searching fordparts .com
they should have the vacuum diagram
Old 05-26-2019, 04:29 PM
Enav's Avatar
Enav
Enav is offline
Rats in my engine bay
[QUOTE=PEG;15152474]Edited Mar 6.
3) [[U]Edit: Answered: they do have barbs.] If this vacuum line has "special" ends - where shown fitting into the 3 - hole rubber tube, attached to air intake (point # 2 in pic).
Thanks.
If yours is same as my 2000 the red and white go to the connector you marked as #2. The rats ate MY #2 and I am trying to find that replacement vacuum collector (3 into 1, to throttle body).
Anyone know that part number?
Old 05-28-2019, 10:29 AM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Go to a junk yard and look for a truck with the same engine and vacuum line set up and get the whole assembly.
You learn where they go and what may be missing and have it over with.
Take photos enough to look at when you install the lines on your truck.
Good luck.
tjc transport
6.2L V8
01-21-2019 06:41 AM
Wolfmancc
1978 - 1996 Big Bronco
10-06-2015 01:22 PM
Ninra
10-04-2013 02:03 PM
Evan_P
06-10-2012 09:37 PM
emick
07-02-2008 07:43 PM
Quick Reply: Vacuum lines sections missing_need info how they connected
