vacuum line routing diagram.
Received 3,107 Likes
on
does anyone have or know where to find a vacuum line routing diagram for my 2014 F250?
i have almost everything put back together except for one vacuum line. i can not figure out where it goes.
somewhere within 6 inches of the passenger side top of the rad shroud.
on
sure, if you could. the line i am looking for is passenger side front. the fan clutch wire comes out of the shroud into the cluster. there is some type of vacuum/electric unit with a "T" in the line coming off it. that line off the "T" is about 6 inches long. i can not figure out where it goes too.
on
PERFECT!!!
THANK YOU, THANK YOU, THANK YOU!!
i never in a million years would have found that nipple recessed into the back of the box, just by feeling for it.
that whole harness plus the fan clutch wires and the top of the shroud were what was ripped out by the damn cat, plus half the sensors on the engine that are further back on the harness.
the replacement harness was dropped off in a box with a "hope this is what you need" note.
on
tofino
10-12-2014 04:19 PM
emick
07-02-2008 07:43 PM
