Keeping track of your build/Build Log
Looking through the build threads it is obvious that some of you are ****, I mean organized. This would tell me that you log your progress in some way. I would like to know how you go about it, other than creating a build thread. Please post any spreadsheets or other digital documents you use.
Thanks
Thanks
Thanks
Thanks
The cost category has two columns - estimated and actual. I fill in the estimated cost after identifying what I want to do or what needs to be done as part of formulating the build plan.
When a part is purchased or a job is paid for, the estimated cost is deleted and actual cost is entered. Below each cost column is a subtotal per subsystem. Each subsystem's subtotal is then summed at the bottom for the project grand totals. One figure gets smaller and the other figure gets bigger.
At the outset, I have a pretty good ballpark figure of how much a project will cost. As the project moves forward, I know what I have actually spent and how much more there is to go.
That's actually why I initially started mine - to see if what I could do within my tax-return budget this year. I started with categories for a couple different scenarios, depending on the scope: transmission-only, transmission plus engine rebuild - reusing as many parts as possible, transmission plus new engine build w/ some upgrades - leaving a running engine to resell at the end. The one thing I haven't done is go back to add in little odds-and-ends stuff I forgot (e.g. a few bolts here, a vacuum fitting there, etc.).
