2002 eddie b expo 2wd blinker issue.
hello folks, i have an 2002 eddie b expo , i noticed a few days that my left blinker would work sometimes and not others, the following day it did the same, then i noticed that if i pushed on the selector a little it would work, later that day it stopped totally and now the left side will only flash the rear bulb fast and the front and mirror bulb wont flash at all. the bulbs are good? thanks for any help, this one is perturbing me.
figured out the problem
well i took apart the steering column and removed the switch come to find out the switch is still good, it was loose connections. the wires when they go into the plugs they worked loose over the years from tilting the steering wheel, i pulled them out and crimped them slightly ad it works like new. hopefully it will last, going to keep the new switch just in case.
dancraig
21
08-06-2012 11:01 PM
T. Pecanic
08-07-2011 08:24 PM
ham-n-swiss
03-06-2008 05:57 PM
