M5R2 1st and 2nd gear not working
First post and im glad i decided to join. Learned alot from previous posts and well ive run into a problem i need help with. I have a 88 f150 5.0 with the m5r2 and well my 1st and 2nd gear aint working. All other gears work. I took apart the top cover where the shift lever goes to and ive checked the shift forks and gears. Idk anything about transmissions so im asking for your help. Pics below.
The forks look ok. Are they solidly attached to the rail, roll pin not broken? By the looks of the last pic I can't see any sign of a roll pin protruding from the hole in the bottom fork, which would be the 1-2 fork. In the first pic the gears from left to right are 4-3-2-1. 5th and reverse are in the rear section. Were there any cuttings or metal fragments inside the case? Was it grinding at all in either gear and could you feel the shifter make a positive engagement (ie, the detents were engaging)? The engagement teeth on the gears and blocking rings look good from what I can see in the picture. How are the teeth inside the synchro ring? Those are the silver rings between the gears.
Actually i stuck my magnet into the bottom and pulled like a very thin semi circle piece of metal and i guess there isnt a pin. Before it stopped working there would be grinding when going from 1st to 2nd and a little going from 2nd to 3rd. And now that its not working 3rd to reverse have the normal tension but 1st and 2nd are very loose. All that was before taking off the cover
Well i checked the shift forks and they are solid, the pin is there its just flush, drained the atf which it was full and good, and found these metal shards on the plug. There shouldnt have been anything because i just changed the fluid like 5 months ago. I think the thin semi circle i found earlier goes with this.
