M5R2 1st and 2nd gear not working
Old 02-22-2015, 01:26 PM
anthonym92's Avatar
anthonym92
anthonym92 is offline
First post and im glad i decided to join. Learned alot from previous posts and well ive run into a problem i need help with. I have a 88 f150 5.0 with the m5r2 and well my 1st and 2nd gear aint working. All other gears work. I took apart the top cover where the shift lever goes to and ive checked the shift forks and gears. Idk anything about transmissions so im asking for your help. Pics below.
Old 02-22-2015, 01:31 PM
rowdyredneck's Avatar
rowdyredneck
rowdyredneck is offline
No pictures showing. Can you see the shifter rail moving? 1-2 should be the rail on the right side. I'm guessing either the roll pin holding the fork to the rail sheared off or the fork itself broke.
anthonym92's Avatar
anthonym92
Old 02-22-2015, 01:32 PM
anthonym92's Avatar
anthonym92
Sorry took a while to figure out how to post pics
Old 02-22-2015, 01:34 PM
anthonym92's Avatar
anthonym92
Also some dirt fell onto the tranny so all that grainy stuff is dirt
Old 02-22-2015, 01:39 PM
rowdyredneck
The forks look ok. Are they solidly attached to the rail, roll pin not broken? By the looks of the last pic I can't see any sign of a roll pin protruding from the hole in the bottom fork, which would be the 1-2 fork. In the first pic the gears from left to right are 4-3-2-1. 5th and reverse are in the rear section. Were there any cuttings or metal fragments inside the case? Was it grinding at all in either gear and could you feel the shifter make a positive engagement (ie, the detents were engaging)? The engagement teeth on the gears and blocking rings look good from what I can see in the picture. How are the teeth inside the synchro ring? Those are the silver rings between the gears.
Old 02-22-2015, 01:47 PM
anthonym92's Avatar
anthonym92
Actually i stuck my magnet into the bottom and pulled like a very thin semi circle piece of metal and i guess there isnt a pin. Before it stopped working there would be grinding when going from 1st to 2nd and a little going from 2nd to 3rd. And now that its not working 3rd to reverse have the normal tension but 1st and 2nd are very loose. All that was before taking off the cover
Old 02-22-2015, 01:52 PM
rowdyredneck
Is the 1-2 fork firmly attached to the shifter rail? It should not slide on the rail. Can you see if the roll pin is still in place on that fork?
Old 02-22-2015, 01:57 PM
anthonym92's Avatar
anthonym92
Old 02-22-2015, 02:10 PM
anthonym92's Avatar
anthonym92
I will go check now on the fork being loose
Old 02-22-2015, 05:03 PM
anthonym92's Avatar
anthonym92
Well i checked the shift forks and they are solid, the pin is there its just flush, drained the atf which it was full and good, and found these metal shards on the plug. There shouldnt have been anything because i just changed the fluid like 5 months ago. I think the thin semi circle i found earlier goes with this.
Old 02-22-2015, 05:21 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Rowdy, you need to look a little closer at the pics. I think 1-2 fork is totally shot! Looks to me like there isn't anything left to go into the collar!
Old 02-22-2015, 05:26 PM
anthonym92's Avatar
anthonym92
Rowdy told me the fork thats shot goes to the 3-4 gears. From front to rear are the gears 4-3-2-1 then 5-R in the smaller section?
Old 02-22-2015, 05:30 PM
eakermeld's Avatar
eakermeld
Sorry, I was thinking it was flipped over. Either way, you may want to start shopping for a good used top.
Old 02-22-2015, 05:32 PM
eakermeld's Avatar
eakermeld
Wait a minute, 1-2 has to be on the side and 3-4 in the middle, so the worn fork IS 1-2. And yes, 5-r is in the back.
Quick Reply: M5R2 1st and 2nd gear not working
