Copper washers for injector install
So I want to get some spare copper washers (the ones that come in the fuel return line kit) to have on hand. I plan on swapping around injectors some and I don't want to order a second return line kit just for the washers (especially since I am not using the hose or the o-rings).
So does anyone know what the specs are supposed to be on the washers?
As long as it fits in the bore and on the injector, it should work. It just gets squishes till it fills up the cracks anyway...
I've re-used the washers a few times and had no problems -- the bore was still clean; no carbon.
If the washer leaks(or your injector wasn't torqued down right), you'll get the entire bore filled with carbon in short order... which isn't the end of the world either -- it's just a pain to clean when it comes time to swap out that injector again.
genscripter
05-23-2016 09:28 PM
cabloom300
11-10-2013 06:26 PM
442john
05-11-2007 08:45 PM
crazymike
03-20-2007 03:28 PM
