Air compressor electrical hookup/plug question
So I somehow ended up with one of these:
It's a 230V 2hp air compressor and came with a pile of other equipment. Nobody knows if it works. Unfortunately, I don't have a 230V supply at my home or where I can work on stuff and cannot upgrade for various reasons. I do have 230-240V outlets at one of my worksites and can test it there - only one problem.
It appears to have been a stationary shop compressor wired into an electrical breakout box and the plug end has long since been removed.
Here's the question - what is the correct plug for the thing so I can plug it in to test? There were several options at the local home unimprovement center and the info on this thing seems a bit spotty. Here's the electric motor's data plate.
I know of the NEMA plugs, but I'm a bit confused - should this use a NEMA 6, 10 or 14 plug? Thanks for any help.
Okay, the whole cable assembly disappears into the motor housing, guess I will check to see if it's grounded to the chassis with my multimeter in the morning. Or should I take the housing apart to double check?
According to this chart it should be a 10 or a 14
NEMA Straight Blade Reference Chart
The other styles are for different voltages. The motor says 15 amps, but that might be a little touchy if your outlet is just a 15.
F6 has probably done many of these, but the first time I tried it, I'd want to have the switch or circuit breaker close at hand.
Good Luck,
hj
Good Luck,
hj
Received 3,110 Likes
on
on
coolfeet
20
04-24-2019 07:04 AM
