Very hard cold start but runs well immediately after
I have a 2003 6.0 with 120,000 miles. On the first start of every day (regardless of outside temperature) the truck quickly starts and then dies 2-3 times before it stays running. The start is usually accompanied by both white and black smoke that goes away after about 20 seconds. The IPR duty cycle at start up is 85%, but the icp is above 1000 psi and the truck always starts. After it is warmed up, the only problem is a small puff of black smoke under hard acceleration, and the truck starts easily the rest of the day. There is no rough idle, loss of power, etc.
The truck has a brand new FICM, oil cooler, Egr cooler, egr valve, icp sensor, icp pigtail, alternator, batteries, fuel filters, and 8 new injectors. The IPR screen is intact and clean.
Any ideas what could be wrong? Thanks!
At first glance I would think stiction except temps seem to make no differenc.
I would then think maybe a weak fuel pump not keeping up with inital demand.
You would need to monitor everything involved with the injection/compbustion process and actual fuel pressure until the event happened [stall/die]. See what value/values changed.
Then you would know what needs changeing.
Extreme stiction can happen even at 70 degrees. However, that should be accompanied by lack of throttle response, hesitation once your under way.
GP circuit could be compromised, but you should have a CEL with that. Worth an ohm test test just in case.
The 85% during crank isn't good, even if you're seeing 1000+ ICP. Might try a restart with the ICP sensor disconnected.
No mention of Ficm volts KOEO, Crank and running?
Josh
Josh
Do this. The hpop could be slowly leaking out the shift seal, having to reprise after it sits for a while.
I had the exact same thing happen to me about 6 weeks ago. Pulled the FICM and sent to Ed. He said it was good. I traced the problem to the FICM power relay.
Suggest you replace the FICM power relay. The contacts are probably pitted and it does not make good contact until the 2nd or 3rd try. If it is the relay, take it apart and you will see what I mean.
Ed
I checked the IPCV at KOEO, and it's at .22V, but there is a code (p2290) for a bad ICP. Considering both the sensor and pigtail are new I'm leaning toward a bad hpop, but wouldn't that usually cause running issues when the truck is warm rather than cold? I still have to try parking the truck downhill. Any chance a bad FICM relay could cause the icp code or high ipr duty cycle? Also, all FICM reading are 48V.
op1324
02-13-2015 12:20 AM
blowin_smoke_1977
03-19-2013 06:21 AM
