The potential issue I see would be the drain tube is only connected to the drain valve by a non-clamped pushed on fuel line. Depending on the pressure coming out it could potential blow it off and fill the valley with diesel.
I think I paid around $140 after coupon. I forgot to mention you need to purchase the scan gauge 2 online and use the code for the 30 percent off.. Then go to the store and pick it up.
Great links and info guys it's exactly what I needed thanks.
Why are there so many options on o-ring material though and what works best for the drain valve/fuel bowl?
I used to know this. I want to say one works with biodiesel, and the other... not so much. There should be documentation on riffraffdiesel.com to explain the differences. If not, call 'em up. Clay is one of the parts gurus here.
