Idle Air Control Valve
Old 08-19-2010, 12:44 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
Originally Posted by chuckatbond
can somebody shed so light , code p-2004 Intake runner control stuck open. what is it and where is it
Welcome to FTE.
You might try a forum search for [IMRC], (Intake Manafold Runner Control), as there are a number of threads on this forum about it, what it's for, how it works & how to trouble shoot & or repair it.
If you need more info, just "bump" one of those threads, or start a new one just for your problem, from the thread listing page, atop this forum & you'll get replys focused just on your vehicles problem.
This thread is about the IAC, (Idle Air Control), which doesn't have anything to do with an IMRC.
Also atop the forum is a "Tech Info" thread that you may find helpful.
  #137
Old 11-12-2010, 07:50 PM
wrparrott's Avatar
wrparrott
wrparrott is offline
I have a 1998 Ford Ranger 2.5 that will not idle when coming to a stop. Have changed IAC, TPS,Plugs,02 sensors. Checked EGR and sprayed with starting fluid while at idle to check for vac leaks. Still wont idle after raising RPM and coming back to idle. It will idle rough and quit. Help
  #138
Old 11-12-2010, 08:04 PM
wrparrott's Avatar
wrparrott
Question 1998 Ford Ranger 2.5
Will not idle!!! Have changed IAC, TPS, Plugs, 02 Sensors and EGR. Checked for Vac leaks. still will not idle after raising rpm and letting off throttle. engine dies but will restart and idles rough. Help
  #139
Old 01-08-2011, 08:18 PM
DFWBII's Avatar
DFWBII
DFWBII is offline
Hi guys and gals,, I haven't read all posts on this subject but,,, has anyone tried the Ford dealers for this IAC?? seems like they would still carry this in their inventory. What do they do with NOS parts when they get so out-dated?? Just wondering is all.
  #140
Old 01-09-2011, 09:22 AM
greenpus's Avatar
greenpus
greenpus is offline
Buy them from China... like all the other parts
  #141
Old 03-15-2012, 10:08 PM
michigan66's Avatar
michigan66
michigan66 is offline
If your mechanic cleaned the IAC with the same stuff used on the throttle body he did a no-no. He should have used a plastic safe cleaner labeled for cleaning throttle bodies. You may be better off replacing the IAC. Also find and remove the red, plastic tube.
  #142
Old 03-16-2012, 07:58 AM
DBF44's Avatar
DBF44
DBF44 is offline
Thanks buddy will try your idea out.
DBF44
twolf004
Crossovers
01-16-2010 09:56 AM
89/01fordman
11-14-2006 07:41 PM
rhubarb
07-25-2004 06:07 PM
Quick Reply: Idle Air Control Valve
