97 F-250 OBD II?
97 F-250 OBD II?
Hello, I am a new member. I am in need of some information.
I have a '97 F-250 superduty powerstroke, manuel RWD. I am liking to put a tune on it, but I am not sure if it will work through the OBD II. I have looked at other threads and couldn't find a straight answer if it is an OBD II or a OSB-PSD. I do have a data link connection under the dash. With code readers I can't read live feeds so I am not sure if it will work.
If some one can let me know what tuners will work, and if this year and engine is OBD II or not.
Side note, I just bought this truck this past fall and the last owner replaced both computers so I am not sure if they were reprogrammed properly if they need to be.
Eric Fackoury
Ontario, Canada
Eric Fackoury
Ontario, Canada
The engine uses obd2 port yes, it is just below and to the left of the glove box. And yes edge I belive uses the obd port to change software. However that is not recommended. Edge programmers Can wipe out our pcms. Most all of us run a TS 6 position chips. Search TS 6 position on here Or in Google and you should get some results
rich gill
1999 to 2016 Super Duty
19
06-29-2009 09:01 AM
