460 swap and fan issue.
Finally got the 460 in my 78 Bronco last night. Got it together today and running.
Everything I bought work. I used all the brackets from a 79 2wd with 460. Bolted the power steering pump from the 351M on the 460 no problem.
Now to my problem. I'm sticking with the 351M fan shroud and radiator. Well I found out today the 351M fan and spacer will not fit the water pump of the 460. What kind of flex fan and spacer should I get?
For today I put short bolts in water pump pulley and I ran it down the road and back couldn't help myself . It was cold enough outside to keep it cool without fan.
The 460 didn't have a fan on it when I bought it.
My 302 had a 7 blade clutch fan on it so I tried it but it has the same problem as the 351M fan.
After all I've been through this week I can't drive it because of a fan and it really needs to be drive able. My other vehicles have issues right now as well.
Yes, I chucked my spacer up in a lathe and opened up the ID so that it was barely larger than the boss that sticks up on the water pump. It doesn't have to be perfect, but I wouldn't go too much larger than the boss OD, otherwise it could get bolted together crooked and out of balance.
Went down the road to the junkyard and there was a 79 F150 with 460. Still had the fan on it(7 blade clutch fan). Got it for 15 bucks. Took it for a drive today didnt have any bad problems. Came home and fine tuned idle speed, idle mixture, and timing. Purs like a kitten. Next time out I'll see if carb needs further tuning.
bigredkacy
05-07-2011 04:28 AM
