looking for clutch fork (number dummy?)
Hey all, recently bought a 4 speed toploader trans to put in my '65 f100 behind a 390 based engine I'm building.
Numbers for trans are HEH-CC, then 012544 below that. It has the 1 3/8 input shaft compared to the 1 1/16.
Because of this, no parts from my 3.03 trans will fit except hopefully the bell housing. Im fairly confident I can get the clutch kit at my local auto parts store, but I'm having a problem locating a new clutch fork..any help?
I have the one for the 3.03, but like u said it won't fit due to the different shaft size.
The HEH-CC trans is from a 1965/66, but the car parts catalog doesn't specify which engine or which Passenger Car this trans was used with.
None of the clutch linkage and bell housings used in F100/350's are the same as cars.
I had a feeling this was going to be more difficult than anticipated.
From what I read, it came out of a '65-'66 Galaxie, but when I go to order galaxie parts, it shows 1 1/16 inch stuff, and no clutch fork.
The entire assembly is simple enough that I can modify it to work, I just need to find a fork that will fit the larger throwout bearing
The clutch fork you have now (C3AZ-7515-C) is approx. 12" long, was used in 1963/64 Galaxie 406/427, 1965/69 F100/350's (all I-6 & V8) and 1966/69 Bronco 289/302.
The problem is, the car FE bell housings are different than the FE F100/350's.
Right parts catalog pic: 4 speed top loader input shafts (7017).
Thanks for the info Bill.
Right now I'm tempted to buy a jegs/summit fork that accepts a 1 3/8 throw out bearing and shimmy that in somehow.
Or get creative and fab up my own.
Out of curiosity (and directed towards everyone reading including Bill) I'm wondering if I could use a passenger car bell housing, what's different about them?
MichiganLarry
12-28-2015 03:17 PM
pburress
03-20-2012 11:19 PM
