Looking for 66 flareside bumper and brackets..
BBAA-17906-A .. Flareside & Uni Rear Bumper-Painted Channel / Reproduced
1948/52 F1/F3 / 1953/72 F100/350 Flaresides / 1961/63 F100/250 Uni's / 1973/77 F250 Flareside 4WD (High Boys).
The bumper fits all of the above but the brackets are specific to certain years and series.
1973/77's use different brackets than 1957/72. 1948/52 & 1953/56 are different again. F100/250's use different brackets than F350's.
2 each) B7C-17787-C Right & B7C-17788-C Left .. Rear Bumper Brackets
1957/72 F100/250 Flaresides / 1957/66 F100/250 with "wrong" Styleside beds / 1961/63 F100/250 Uni's.
ND...wondering if you could help me out with this problem... A member here is offering me a bumper and brackets... The bumper looks correct.. But the mounting brackets are spaced over 37" wide... My frame rails are 34".. The gentleman that is offering it to me is not sure of application... could you tell me which truck this might belong to? ( what truck has frame rails separated over 37").. Trying to determine if it's just a simple bracket change..or is the bumper not correct also...
Any help would be appreciated..
Thank you
Thank you
37 1/2" = The Flareside bumper (D3TZ-17906-C) is wrong and so are its brackets.
37 1/2" width between the inner frame rails behind the cab:
1973/79 F100 & F250 2WD - 1975/79 F150 - 1977 F250 4WD from serial number Y20,001 (not a High Boy) - 1978/79 F250 4WD
33 1/2" width between the inner frame rails behind the cab:
1961/72 F100/250 - 1973/76 F250 4WD - 1977 F250 4WD before serial number Y20,001 (High Boy).
columbia1spring
10-07-2017 06:12 AM
moparmusclecars
16
09-09-2017 08:01 AM
moparmusclecars
03-20-2012 10:52 AM
