HELP ASAP. Truck won't start intermittently. Need info
Old 02-15-2015, 08:40 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Did swamps think they could repair your IDM, or are you looking for another one.
I didn't want to throw parts at my truck, but because I need my truck to make money, I figured I'd lose more money with it not running than spending it on parts. $500 later it's running. And we all learned something.
I still need to do uppipe donuts or bellowed upgrade. I wanna do a riffraff wheel and maybe a blank pedestal and outlet (or van turbo). Just get some supporting mods done before I start doing major upgrades.
Old 02-15-2015, 08:53 AM
Backdraft-14's Avatar
Backdraft-14
Backdraft-14 is offline
The idm can be rebuilt, I went with the upgraded version. IIRC they should have it rebuilt by Tuesday and 4 day shipping back. Keep us posted on your upgrade progress (in a new thread).
Robert
Old 02-24-2015, 09:00 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
So now the darn truck is stalling when I come to a stop....
What the heck.
I slow down and when I'm almost stopped, the engine will go quiet and then stall. Starts back up afterwards, sometimes it takes longer to crank. I'm going to pull the IDM and see if it's wet inside.
I gotta look up and see how much swamps charges to check out an IDM. I'm going to go to junkyard and get one out of a truck, but it says on windshield, "cranks but no start". May be worth getting checked out.
I just can't win with this truck. this weekend the belt decided to shred and ride up on the ac pulley and ruined the plug on the ac compressor and almost cut through my upper radiator hose.
Old 02-24-2015, 09:06 AM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
How old is your ICP sensor?
Old 02-24-2015, 09:39 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
New
CPS
ICP
IPR
ICP plug had a little oil in it but I cleaned it up with carb cleaner.
Hpop reservoir is full. Fuel pressure stays above 35psi
I have not yet taken valve covers off. I'm waiting for low to mid 30s (or higher) before I start that project. I don't think that's anything to do with stalling though.
Old 02-24-2015, 09:42 AM
white Buffalo
Hmmm.....fuel pressure? IIRC stock pressure should be about 56 psi.
Old 02-24-2015, 09:48 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Stays above 35 when I'm demanding power. Idle fuel pressure is a little low at around 46-48. I was thinking about shimming the spring, but under full throttle it doesn't get below 35psi. I don't think that's the issue.
Old 02-24-2015, 10:05 AM
white Buffalo
I agree with you - but this issue needs to be addressed before moving on IMO.
Old 02-24-2015, 10:07 AM
white Buffalo
My Excursion would stall once in a while when I came to a stop lightfrom a bad ICP sensor.
Old 02-24-2015, 10:42 AM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
ICP sensor is new from ford. So unless the plug is damaged it should be fine.
New regulator as well.
I'm saving up for the riffraff frx, so I'm not messing with shimming the regulator and worry about it leaking with an old oring. I do agree it should be more fuel pressure, but it's got a new fuel filter, and the old one wasn't black from leaking injector orings. Very happy about that.
I thought it may have been the ebpv but I unhooked and wired that open.
Old 02-24-2015, 02:08 PM
white Buffalo
Swamps charges $37.50 to test an IDM.
Old 02-24-2015, 02:09 PM
white Buffalo
I can't remember, do you have A&E or something to watch the ICP, ICP DC, voltage, rpm's , etc....?
  #28
Old 02-24-2015, 02:41 PM
white Buffalo
Also, have you individually checked your batteries or voltage while at idle?
  #29
Old 02-24-2015, 06:12 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
I don't have AE... I should though with 6 psd trucks and a fleet of other fords.
Alt is fine. Batteries are not that old. They have a 2014 sticker on them. Voltage must be ok because my headlights don't dim at night before it stalls. I haven't checked exact voltage though.
luke1144
07-28-2016 07:48 AM
Dave O'Brien
05-06-2013 10:42 AM
IDPisan
17
01-23-2008 09:42 PM
drag_racer
08-14-2006 07:25 PM
troubled7.3
21
06-28-2006 08:36 AM
Quick Reply: HELP ASAP. Truck won't start intermittently. Need info
