Extended Cab Door Latch Cover
I'm having a lot of trouble finding the upper rear door latch cover for a 2006 F150 extened cab. I've attached several pictures for reference.
On the inside it says: 5L34-15519C39-A
3525 CAV 8 LH
PP C 1868
All I seem to find is forum links that go nowhere. Any and all help is greatly appreciated.
3525 CAV 8 LH
PP C 1868
HINGE COVER
DON'T KNOW ABOUT A NEW ONE BUT I CAN TELL YOU HOW I FIXED MINE WITH THE SAME PROBLEM. GO TO HARDWARE STORE WITH THE STOCK BOLT AND GET TWO BOLTS 1/2 INCH LONGER THAN STOCK. ALSO GET TWO 1/4 BY 1 INCH FLAT WASHERS. THE HOLE IN THE COVER IS TAPERED AND THE WASHERS STOP ABOUT HALF THE WAY DOWN AND SECURE THE COVER. DON'T OVER TIGHTEN ...JUST SNUG TIGHT
They are also available online from eBay and Tasca Parts. Search for Ford F150 Interior Door Latch Cover. The part fits all extended cabs from 2005 thru 2010. Part number in earlier post is correct for flint color. Tasca lists them for about $31. Hope this is some help. It is a snap to put in -- 2 screws.
Replacement Latch Cover
None of the links I have found in this thread have worked so here is the new link to purchase replacement inside door latch covers for F-150 Extended Cab. Fits 2003-2007 F-150.
https://parts.ford.com/shop/SearchDisplay?searchTerm=15264B83&storeId=1405&cat alogId=251&langId=-1&searchType=partnumber
If the link doesn't work go to parts.ford.com and search for part#15264B83 listed for $22.22
bmoore79
05-28-2021 12:43 PM
tiny1
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
10-13-2017 12:00 AM
taylorjgreen
02-23-2014 02:34 PM
