help pulling y block
If it was assembled once, it should go back together again. Take pics to help your memory. There are few things as frightening as a nearly removed engine swinging from a fully extended hoist. Take the clip off and reaffirm your smartness.
My welder does not have the capacity to make a lifting plate so I'm back to the leveler. Is there anyone who has used the leveler who can tell me the best/safest place to connect the four chains? Before I attempt the lift I will make many measurements to verify that I have the clearance I need.Thanks
What may appear as black paint in the photo is probably an inch of crap covered in fresh oil. If I recall correctly, one cylinder has no pressure and the other seven have low pressure. I have been wondering what to do with the engine and transmission. Don't have plans to rebuild it and can't store it for long. Last thing I would want to do is pass on my problems to someone else. I am more of a buy high sell low kind of a guy. Not a very good business model but I never ripped anybody off that's for sure. Then there is the wife. She thinks these parts are made of gold. Not her fault though since I borrow gold from her to buy the stuff in the first place. Anyone care to give me some direction?
Yougotthehit
05-05-2012 10:31 AM
MHull
11-15-2005 09:07 PM
