CONVERT 5 LUG TO 8 LUG
For the front you just swap out the complete front knuckle and everything attached to it, minus axles shafts. For the rear quicker and easier to swap out the complete 9" for a Dana 60.
"8 lug thug" yes that is funny. And I to am curious why you want to do this, is it so you get different rims that you can not get in 5 lug?
Or are all your parking lot buddies 8 lug thugs....lol Alot of work, for not a lot gained in the end IMO cause it will still be a 1/2 ton truck.
You truck, time and $, so go for it, post spme pics.
I do believe its more than a spindle and rotor swap, your 1/2 ton has a single piston caliper and the 8 lug rotor takes a duel piston caliper.
I'm interested in this conversion for my '79 150 for the 8 lug wheels and dual piston calipers.
Why would you want 8 lug wheels? The bolt pattern makes it harder to find wheels and the wheels make it very expensive to find tires.
There didn't seem to be any problems with stopping, in 1979, with the 5 bolt pattern so why would it suddenly become an issue now?
Why complicate something 150% for a debatable 1% gain?
You know how us old guys used to make 'em stop faster? We didn't have phone in our hands when we were driving AND we started braking sooner.
Good luck
Good luck
In my case, it'd make it easier to rotate tires amongst the three trucks...lots of spares
But then again, the F350 studs are 9/16...and left-handed... (actually, I had the left-handed studs swapped for rights, but from the factory...ugh...)
I’m doing the front end from 5 lug to 8 because I replaced my rear 8.8 (on my bronco) to a Dana 60 4.10 FF. Nothing worse than having to carry 2 spares because of different bolt patterns.
Not that one shouldn't do such a thing, but I'd wonder why do such a thing.
I thought about this once many years ago for my '77. As I recall, the front hub bearings were the same on a Dana 44, both for F-250 & F-150s. I was never sure about rotors working with single piston F-150 calipers, so I decided if I ever did it, I'd get my front rotors drilled for 8 lugs …. OR …. I'd get the rears drilled for 5 to match, or otherwise adapt. I dropped the idea in due time.
Nothing?
One maybe could build themselves a special spare wheel to fit both hole sets?
I still have the older large body (heavier weight wise)18 volt version, still a torque monster. Or get this and get your "8 lugger" swap on. https://www.dewalt.com/products/powe...l-only/dcf896b
1/2 drive like most impact rated sockets that are common lug nut size. 330 ft-lbs of max fastening torque and 600 ft-lbs of max breakaway torque to complete a wide variety of applications.
Or if you want a air run beast. https://www.lowes.com/pd/Ingersoll-R...Wrench/1062885
Great for changing your "8 lug 3/4 ton 79 F250's ol stocker rims out for some new ones. No more blisters from 32 lug nuts off and then 32 back on. lol
Here is something to cry over, and they need step torqued. Thanks goodness they are only 5 lug nut install rims. I was so tired of step torquing 32 bolts FOR EACH RIM, I did not mount them until the next day. lolX2
cstronko
08-26-2022 07:35 AM
jeffj2689
11-22-2007 06:34 PM
ford7379trucks
04-12-2002 08:27 AM
