2002 7.3 powerstroke
I assume no Check Engine Light. So, no codes.
I have a series of questions that may help the guys figure out the problem.
1 How many miles are on the truck?
2 When was the last oil change? What type pf oil are you using?
3 What about the fuel filter? Have you changed it?
4 How much fuel is in the truck? Do you park it on a hill? (there is a problem with some trucks that start sucking air when the tank is still half full, that's why I ask)
5 Is it cold where you're at? Did you add any fuel anti-gel?
6 Have the injectors had any work done? O-rings? Aftermarket injectors?
Answering these questions may help in finding out the problem.
The check engine light comes on sometimes, but when i shut the truck off (when i finally do get it running ) the check engine light goes away and no codes. There are 140,000 miles on it, the oil change is about due not sure what oil is in it (i just bought the truck in july ) i will put rotella in it. There is about 1/2 tank of fuel in it,and it is parked on level ground. Yes it is cold here , i never added anything because once it started getting cold here is when it started acting up, so i pluged it in and parked it until i can get it fixed. Not sure about the injectors at all. I hope this helps.
