Oil Cooler Deleted, pics inside
#31
Sorry, not familiar with the internals of the oil cooler and common failure points...
#32
on
I removed the cooler on my 460 because my F150 frame was not chamfered for it. I did a similar install to yours except I mounted the filter up behind the bumper to protect it. I used braided SS hoses from Summit.
My next door neighbor bought a '94 F150 for his daughter and it has the 351W. When he got the truck, the cooling system was rusted very badly, so I recommended we remove the cooler lest it fail. It's still sitting on my workbench. We just replaced his lower radiator hose with one for a 302.
#33
#35
2)The nipple that the filter screws onto can be removed with the appropriate size hex/allen wrench from the sandwich plate. Screw that back into block.
3) Use a standard non-oil cooler lower radiator hose.
4) You can now use full size filter, (Usually FL-1A)
Here's the sandwich plate being removed from my 5.8:
Here's the Transdapt dual setup I mounted on the framerail:
#37
https://www.ford-trucks.com/forums/1...-addition.html
#38
Yes they did Brad. They had an air-cooled unit mounted on the driver's side of the core support.
#39
The pain in the butt was the gasket for the oil cooler manifold. It wasn't the same as the old oil cooler i believe and not the same as an oil filter gasket.
#40
If you can't, let me know. Lkq is having a 1/2 off sale in 3 weeks by me, they have a ton of 87-91 trucks, usually more than 92-97. I'm going anyway. All the items were light weight enough that shipping would be fairly cheap to PA. I'll also keep an eye out for that tailgate emblem you had been looking for.
OK< thanks. But I THINK the yard come to me just got a brick F350 and I am pretty sure it is gas
#42
1)The sandwich plate (part with 2 hose nipples) can be removed from the block. It has a metal tab to keep it from rotating. Bend it & unscrew.
justplumducky
10-14-2017 12:59 PM
Phil527
09-14-2010 04:08 PM
fordberg
04-04-2004 09:31 PM
