1951 F1
Old 01-18-2015, 07:16 PM
1951 f1 two's Avatar
1951 f1 two
1951 f1 two is offline
1951 F1
Bought truck with a Camero front clip half done, corrected welds and installed plates. Dropped 350/350 auto in it, has what appears to be tilt column out of same car. Problem is cannot get column to align straight with rag joint on steering box, angle is very low. Read some other post here about using van column, is that van column the only way to go? Thanks Chris
Old 01-18-2015, 11:35 PM
gearhead1952's Avatar
gearhead1952
gearhead1952 is offline
Rag joints pretty much need a straight line from column to box. Could eliminate the rag joint and go with a u-joint.
Old 01-19-2015, 08:00 AM
TonyB55's Avatar
TonyB55
TonyB55 is offline
My F-1 has a Firebird front clip and tilt steering column, also.
The P.O. Notched the floor for the column, right above the brake/clutch pedal access plate.
This allowed a relatively straight line at the rag joint.
What year clip is on your truck? Mine is from a 79 Firebird.
Old 01-20-2015, 07:55 PM
1951 f1 two
Was told it was a '69 Camaro, column is same, maybe i need to notch up higher to get straighter? Thanks for help.
Old 01-20-2015, 09:12 PM
1951 f1 two
Thanks, i will check into u-joint.
Old 01-21-2015, 08:11 AM
TonyB55's Avatar
TonyB55
TonyB55 is offline
If it's a 69 Camaro subframe, it will have the steering box behind the crossmember vs. my 79 Firebird/camaro subframe with the steering box in front of the crossmember. So, my earlier info won't be relevant for your problem.
telefunkken
WTB - Parts & other
08-06-2013 02:50 PM
Ryan Sigman
04-13-2013 11:49 PM
robramsey
03-03-2013 04:18 PM
DJOHNSTON78
09-29-2008 10:34 PM
ABOERNER
09-29-2003 04:34 AM
Quick Reply: 1951 F1
