Lock Punched In, Need advice!
Hi everyone, my 2009 Ford F150 was broken into and they punched in the lock cylinder on my driver side door. I am being told that I have to buy the Lock Cylinder ($86) and the Door Handle Assembly ($230). But I have been reading online that if the keypad entry still works (which it does), then they probably did not break the inner door handle and therefore, I can just buy the lock cylinder. Does anyone have a similar issue and some advice on how they resolved it? I would hate to have to pay $418 (with labor) for the door to get fixed. I can still lock and unlock the door with the remote and the keypad, so its not 100% necessary that I fix the key entry. I just want to take care of the truck for future resale value as best as I can. I would appreciate any feedback!!! TY
I would check on eBay or do a Google search. I would bet you can get a better deal yourself. Also the door panels come off fairly easy, you may want to look into fixing it yourself. Me I'm not sure I would fix it (unless it looks bad), I haven't used a key to get in a vehicle (excluding my 67 Cougar) in over a decade.
Don't you have to repaint the door? A few years ago the lock cylinder was pried out of my mustang and the most expensive part of the repair was painting the door.
I would leave it alone, park it where it was broken into with a cell phone on the dash...waiting quietly in the bushes with a shotgun. Fill the shells with whatever you want from rubber to salt to...
Might be worth a second look at the policy.
I have a used 2009 drivers door handle with the keypad that I would give you if you need it. It is a little faded (not bad) and the #3 button is burnt out.
With some plastic paint it would look new and you might be able to find just the key pad part? Msg me if you would like it and I would just want the cost to send it postal service
Exterior Driver Door Handle No Key Hole w Pin Pad Holes Fits '04 14 F 150 | eBay
These are QUICK, CHEAP, and EASY... I have one on my truck.
metriccar
1999 to 2016 Super Duty
02-10-2015 10:19 AM
akuhr93'f150
23
01-10-2013 08:04 AM
HighOctane
26
11-18-2010 10:53 PM
