Washer nozzle removal w/out removing cowl?
Old 01-11-2015, 02:51 PM
Jeff W.'s Avatar
Jeff W.
Jeff W. is offline
Hey gang,
While I'm doing work over the next week, my washer nozzle is most probably clogged. Is there a way to remove it w/out removing the cowl? Its on an '89 F-150. Single nozzle with the two spray ports.
Old 01-11-2015, 07:22 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,178 Likes on 2,215 Posts
nope.
but before you remove the cowl, try blowing compressed air into the nozzle and out the line, you may blow out the obstruction.
Old 01-11-2015, 07:29 PM
ponykilr's Avatar
ponykilr
ponykilr is offline
Yep, a rubber tipped blower may fix it right up.
Old 01-11-2015, 07:34 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
I used the ole garden hose to back flush mine. Just take off the washer hose(at washer pump) to allow the crud to get out of the system 1st!!!
Old 01-12-2015, 11:20 AM
Jeff W.'s Avatar
Jeff W.
Jeff W. is offline
Thanks guys. I'll try and flush it first. I took the hose off at the reservoir and was able to blow fluid through the ports, but may not have cleared it enough.
bigboylk
1978 - 1996 Big Bronco
12-23-2017 03:48 PM
peka
12-04-2015 12:25 PM
BPofMD
1999 to 2016 Super Duty
09-12-2015 09:57 AM
glovemeister
24
01-28-2011 06:41 PM
2ndmouse
04-22-2004 06:37 AM
Quick Reply: Washer nozzle removal w/out removing cowl?
