how to remove...
Old Apr 18, 2004 | 10:06 AM
2ndmouse's Avatar
2ndmouse
how to remove...
hiya!
work is progressing well.. I have run into a small problem I am sure one of you knows.
on the top of the hood, under the windshild there are "slits" where your wipers come out of and warer drains in and air comes in. in a newer truck this "plate" comes out via a few screws.
now... set the way back machine to 1965.
how, without using a saw (NO NO!) do you get this open to remove 40 yrs of leaves crud and crapola??
I noticed this was half full as I was replacing the washer tank... and discovered there are no washer jets pointing at the windshield, so I have to fabricate them somehow (unless they are "different"). I have a dual motor tank unit off an old 280Z, so I had a great idea to run really thin lines up the wiper arms to the pivots and let it "spread" water over as it wipes (when I push the button to make the washer go).
I gotta get this gunk out! HOW?
THANKS!!
Old Apr 18, 2004 | 01:13 PM
ddavidv's Avatar
ddavidv
You're talking about the cowl vent panel. The geniuses at Ford welded this piece as part of the cab assembly.
BTW, I have some hoods with washer jets on them. Not in the nicest shape as far as chrome, but if you want 'em, you can have 'em.
Old Apr 18, 2004 | 10:36 PM
2ndmouse's Avatar
2ndmouse
thanks for the offer, I already rigged the hoses it works good..
ummm.. how then do ya clean out all that crud in the cowl vent?? a few well placed holes and a shop vac hose??
I dont reall wannna start making holes but.... the cruds gotta go.
Old Apr 19, 2004 | 04:43 AM
jowilker's Avatar
jowilker
Have you tried compressed air to stir it up pull it out. The vents that go down to the foot can have the covers removed for access.
Our trucks have the washer jets out on the hood.
John
Old Apr 19, 2004 | 08:38 AM
smcafee's Avatar
smcafee
I cleaned mine out by removing the vent covers on the inside lower fenders and reaching up, down, and around with various hooks, rods, and other raking objects to pull the stuff out. Other than blocking air flow and being an unsightly mess, I had a friend who didn't clean his soon enough. Finally the pine needles worked thier way into the area behind the heater where the fan resistor is mounted in the back of the air plenum. Started a fire one day while driving to work. Thats when I cleaned mine.
Old Apr 21, 2004 | 08:41 PM
2ndmouse's Avatar
2ndmouse
my hood doesnt have any "holes" where a washer jet should be. Might be a different hood?
fire.. theres a clever way of removal!
Old Apr 22, 2004 | 12:41 AM
camperspecial65's Avatar
camperspecial65
I had this fun chore on my 65 after it sitting a few years....just blasted the heck out of it through grill sending crud to one side or the other....before doin this, If you got the 65-6 type floor vents, open up and reach down and pull crud out before adding more from topside. They did put a fair size drain hole at rear you can see easily from under truck....leaves and twigs are a bear though....I just got a 66 I am gonna have to do it to...oh boy
As to the washers....they were an option that was on the hood itself...usually in Custom cab models, but not always.
Happy cleaning
camperspecial65
Old Apr 22, 2004 | 06:04 AM
William's Avatar
William
Shop vac, water, elbow grease. Some had the windshield washers some didn’t. Dodge uses a squirter nozzle that fits in the slits in the cowl. A little plumbing and a couple of screws gets the job done without boring holes in the hood. Looks nicer as well since they are nearly invisible when installed .
Old Apr 22, 2004 | 06:37 AM
44dwarf's Avatar
44dwarf
Just take it down the hi-way at full speed and open the vent doors!! You'll get all that junk out!!
44
