Overall rating of the IDI
#46
Received 3,118 Likes
on
I never said it was bad or not better. Jesus, let it go already.
The company I used to work for bought a '97 F-700 at auction that was a former US Navy truck, with a 16' flatbed on it, rated to haul 8000 lbs (GVWR was close to 20K). It had a 160 hp Cummins in it and a 5 speed Allison, and dear God that truck was slow. A big part of the problem was the ratio spacing in the Allison- first and second weren't bad, but as soon as it went into Third it just bogged. I drove it once with almost 8000 lbs on the bed and it could barely do 35 mph uphill, because it couldn't go past second gear.
Why you would put a 160 hp engine in a truck that size I will never know. I think it was only rated for 400-some ft-lbs. It did actually get fairly decent fuel mileage for a truck its size though, would still pull down mpg's in the teens despite the fact you were running close to 3000 RPM on the highway at 70 mph!
these trucks were almost new, and had been converted to attenuator trucks with an arrow board mounted behind the cab. by law they had to weigh at least 20,000 lbs to be used as an attenuator.
so we would weld a 1 inch steel plate to the frame, then mount the arrow board to that, and hang the attenuator on the back.
this would run them over the scales rite around 21,000 lbs full of fuel and a driver.
as to why ford puts those turds in the F600 and F700 trucks, the only reason i can think of is because the sheeple have to have a cummings.
then once they have it they realize how big of a turd it is and sell it off at a loss to some unsuspecting fool that has to have a cummings and replace the turd with a cat diesel powered truck that will actually be safe on the road with a load on the back.
for a while there we were buying 2-3 year old trucks with under 30k miles on them at auction to make attenuator truck out of for under $10 grand because no one wanted them.
10 year old trucks with 200k miles that had cat power were selling for the same 10 grand or more.
#47
The reason an IDI (or most V8 diesels) work better than a Cummins for pickups is the limited operating range of the I6. More transmission ratios help this, but for a four, five or even six speed truck, the rpm limited power band makes them less than ideal unless heavy hauling is all it does. Just look at the first pickup-specific design from Cummins-the new 5.0. They went with a V8 design, no doubt not only due to packaging but the more pickup-friendly operating range.
Past that if you tell me you need more power than an IDI can deliver, you need a bigger truck. Just had a full exhaust put on the 97 and a 6pos chip. Thing is a beast now, by the numbers it should be around 330bhp which wont pull a backhoe up a 6% grade at 70, that is just fine by me, it has more than ample power to do what we need it to, and that is all I (or anyone really for that matter) needs. Im being practical of course... so bring on the flaming.
#48
I am an IDI fan. Had em' for 5 years now. The main thing that interests me about 12 valves nobody has mentioned yet. That is, they are all mechanical and direct injected. Show me another easy to find engine with readily available transmissions that is all mechanical and direct injected and i'd love to know more about it.
#49
I figured the reason Ford put the small Cummins in there was that it made for the least expensive diesel option for fleets, US gov't contracts, etc. Kinda like how they used to put the 300 six in the F250 and F350 and even some medium duty trucks, which was probably agony to drive. I read that there was a 180 hp and 200 hp Cummins option available, but the US Gov't isn't about to pony up for that.
For awhile I was seriously considering talking my boss into ordering a fuel plate and some other stuff for it to bump the power but I never did.
Oh and yes, my old boss got that truck super cheap. They bought it in 2007, so they got a 10 year old F700 with almost no miles on it (I seriously think it had like 30K on it when they bought it-obviously it never left whatever base it was on), with a flatbed and a liftgate, for something like $8000. It was a good reliable truck though.
#50
on
That was specifically the point i was trying to make... lol not sure if it got through.
never had any problems with grades. drop from 5th to 4th around 55, and on some real long or steep grades maybe drop down to 3rd. but i was never any slower than semis, and usually had to back out of it because they were going slower than i was.
#51
Our Cat TH330B on a wilson 25'? dovetail with 14k axles is not fun to pull with the 92. That said, thats not the engines fault, theres a reason we usually pull it with the freightliner and lowboy, but the FH was haulin hay. Gross combination was 32k +/- a ton. topped a 3/4 mile 6.5% hill at 30mph lol, 265k on stock fuel system, major exhaust leak pre-turbo, and still had to back out of it because it was overheating(100+ that day)... still havent got a radiator yet. I can pull 15k of hay on the same trailer up the same hill at 45 in the winter, about 3/4 throttle due to pyro.
#52
on
it really is amazing what these engines can do with a turbo, and minor tuning to a stock engine ain't it hairy?
the only thing i hate about the 88 is the fact it weighs 9100 lbs, and if i forget to put it in 4X4 before going off road it sinks to the frame because the damn thing is so heavy.
#53
#56
#58
on
trevorrules
12-13-2014 09:41 AM
ghunt
10-20-2006 12:26 AM
kitsapcountychopper
03-08-2004 06:08 AM
