6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Power fold mirrors stopped working
Old 01-07-2015, 03:45 PM
MikeRizz's Avatar
MikeRizz
MikeRizz is offline
My mirrors will not power fold in or out anymore? They will still retract/and extend as well as adjust. But no power fold. I checked the fuse and it is good. I am guessing the switch may be faulty? Anyone had this issue?
Old 01-07-2015, 06:18 PM
dlibson's Avatar
dlibson
dlibson is offline
I'm assuming you know the switch needs to be in the middle, not the left or right mirror position. If not, do that.
If you do, switch would be next culprit. Then the mirrors themselves. But that would be odd to lose both right away. Also, I have had them freeze.
Old 01-08-2015, 05:18 AM
senix's Avatar
senix
senix is online now
Received 1,419 Likes on 1,014 Posts
You can take it loose and see if the connections are bad but honestly I can't see how some of it works and rest does not.
Old 01-08-2015, 05:13 PM
MikeRizz's Avatar
MikeRizz
MikeRizz is offline
Yes I did know that.
I will source a switch and try replacing it. Agreed I cannot see both mirrors failing at the same time.
Old 01-08-2015, 05:15 PM
MikeRizz's Avatar
MikeRizz
MikeRizz is offline
I though of this but the way you power close them is a different position on the switch. So I assume it is possible just that contact failed.
Old 01-08-2015, 11:56 PM
hotairgypsy's Avatar
hotairgypsy
hotairgypsy is offline
before you replace the switch you can test it out very easy...pull the switch panel on the top of the door and look at the plug going to the switch. There is one wire which goes directly to the power fold relay. it is a momentary ground trigger so all you have to do is tap it to ground and if the mirrors fold in or out then you know it is the switch. if it doesnt then it is probably the relay. keep in mind you can test the switch also and check the one wire goes to ground when you pull down to trigger the mirrors to fold in.
think the wire you are looking for is grey/brn wire...test it with a VOM meter and you will know
if you land up needing a relay write me...i sell them on fleabay(321544244172) cheaper than anyone
Old 01-09-2015, 10:26 PM
MikeRizz's Avatar
MikeRizz
MikeRizz is offline
Great info I will try this this weekend. Thanks!
Old 06-06-2015, 09:56 AM
MikeRizz's Avatar
MikeRizz
MikeRizz is offline
This process was spot on! Thank you. In my case the switch was bad. Ordered a new one ( about $30 ) and all is working again.
Old 11-20-2015, 01:18 AM
Larry NCKS's Avatar
Larry NCKS
Larry NCKS is offline
Wink
I can! Just went through it over on Super Duty forum. Both the power fold function and main mirror down function, anything that required a backwards pull of the switch, was gone. Pin 1 (B+) to 4 (Fold/Unfold) had no continuity on an ohmmeter. I would have found the same on the raise/drop pins had I checked those.
Old 01-25-2017, 10:28 AM
ka2rkv's Avatar
ka2rkv
ka2rkv is offline
Does anyone if the power extend is on a different circuit? I lost all function except the extend/retract function.
Old 04-19-2021, 02:18 PM
Brad Hollinger's Avatar
Brad Hollinger
Brad Hollinger is offline
Where does relay plug in for 2011 F350 folding mirrors?
[QUOTEi =hotairgypsy;14978991]before you replace the switch you can test it out very easyi...pull the switch panel on the top of the door and look at the plug going to the switch. There is one wire which goes directly to the power fold relay. it is a momentary ground trigger so all you have to do is tap it to ground and if the mirrors fold in or out then you know it is the switch. if it doesnt then it is probably the relay. keep in mind you can test the switch also and check the one wire goes to ground when you pull down to trigger the mirrors to fold in.
if you land up needing a relay write me...i sell them on fleabay(321544244172) cheaper than anyone[/QUOTE]
Dealer pulled relay for folding mirrors, but didn’t tell me where it plugs in. I purchased a replacement but have no idea where to attach.
b.leevr
08-09-2019 12:58 PM
Frantz
2017+ Super Duty
03-27-2017 10:17 AM
samjen
01-25-2015 02:03 PM
biker
1999 to 2016 Super Duty
05-25-2010 07:06 PM
357fhp
04-27-2007 11:39 AM
Quick Reply: Power fold mirrors stopped working
