Oil & Lubrication
Expedition Oil Change
Old 07-20-2003, 08:26 PM
kallamp's Avatar
kallamp
kallamp is offline
Question Expedition Oil Change
I just purchased an Expedition EB 5.4, just turned over 3000 miles and started to change the oil & filter. I have always changed my own oil but this is the first filter that I have had trouble getting to. My fluted cap wrench doesn't fit, so I tried my band wrench and can't get a good grip on the filter after moving the air filter and reaching down through the top. Do I need to get a cap wrench to fit this type filter?
Thanks
Old 07-21-2003, 10:18 AM
horsepuller's Avatar
horsepuller
horsepuller is offline
Welcome to FTE!
I don't have the answer to your question, but after you read this thread you may decide to have a shop do your first oil and filter change.
Scott
Old 07-21-2003, 03:10 PM
PbFoot's Avatar
PbFoot
PbFoot is offline
Not sure what kind of tool you need to get the filter loose in the stock location. But, since it sounds like it is such a PITA that you might consider replacing it with a remote filter. Mine is located out in the WIDE open where I can acutally get two hands on it and if needed virtually any kind of filter wrench will fit. It is even mounted verticle vs horizontal, so there is minimal sippage when I unscrew it!!
Pbfoot
Old 07-21-2003, 03:12 PM
PbFoot's Avatar
PbFoot
PbFoot is offline
Pbfoot
Sippage? Oops, meant "spillage".
PbFoot
Old 07-22-2003, 01:24 PM
drdave's Avatar
drdave
drdave is offline
PBfoot, where did you mount your remote oil filter adapter? Which filter do you use? I have a Perma-Kool relocation kit but the oil filter adapter did not fit the original type replacement filter so I abandoned the idea of installing it this time.
Old 07-22-2003, 05:49 PM
PbFoot's Avatar
PbFoot
PbFoot is offline
drdave, I have a 97 expy. The filter is now located up high behind the front bumper on the driver side. It was there when I purchased the vehicle. It is up out of the way and pretty safe from flying debris, etc. I can't remember off hand what filter it uses, but it is a very very common model. When you say the oil filter adapter did not fit the original type filter, are you talking about the adaptor piece that goes onto the engine block or the other adaptor, that goes to the new filter location? The end that goes on the block obviously must fit the same as the original type filter. But the other end does not have to be compatible with the original oem model filter, so long as you have a filter that fits and is a size that you are happy with.
Hope this helps,
PbFoot
Old 07-23-2003, 09:24 PM
erik_herrling's Avatar
erik_herrling
erik_herrling is offline
I have found the same thing with my 2000 F150 4.6l. I consider myself to be a pretty handy guy, but getting to my oil filter seems impossible. I haven't tried it yet, but from looking down from the top and up from the bottom, I can't seem any way to get to the filter. Any advice? I would love to start changing my own oil, I perform most of the other basic maintenance but have stayed away from oil changes just bc I can't get to the filter.
Old 07-24-2003, 02:05 PM
golakers's Avatar
golakers
golakers is offline
Try turning your wheels to the left (or is it the right??). Doing so will give you extra clearance from below.
johnkn
2015 + Expedition & Navigator
06-08-2015 06:06 AM
Todd Fuller
1997-2006 Expedition & Navigator
15
10-28-2014 12:26 PM
blueoval65
2004 - 2008 F150
01-08-2010 08:50 AM
poppie
09-10-2007 06:45 PM
Fuzzy T
1997 - 2003 F150
36
05-16-2003 11:02 PM
Quick Reply: Expedition Oil Change
