Blend Door/Heater Core Questions
Hello everyone,
So when I bought my truck the radiator leaked. So, I have since replaced the radiator, put in a Ford thermostat, and put fresh 50/50 in. I'm having trouble with the heat now.
First, it only gets slightly warm, almost not warm at all. And then while your driving it will randomly go to being cold air basically ambient (it's cold out). Also the temp guage will go up to like the "m" and the fall back down, it seems to fluctuate a bit. Even when it's reading higher the heat does not warm up.
The heater core has one hose that's very hot but the other is only kinda warm. Does that mean it's clogged? Should I try flushing it out?
I checked out the blend door today, I removed a pen and a pencil from it and it removed some of the notchiness in the temp switch. It still does not completely close and allows cold air in. Does that mean something is still blocking it or is it supposed to not close all the way?
I appreciate any input, it's too cold to be driving with no heat!
Received 3,114 Likes
on
on
Alright, I've got heat that will melt your face!
Started by flushing the cooling system for the 2ND time. Then I was able to remove another pencil from the blend door once I had the heater core out. I went ahead and still replaced the core, black fluid came out of it when I dumped it out. Installed the new core, put everything back together, filled up with antifreeze and distilled water and it works flawlessly!
Don't know if doing just the blend door would have fixed it but it was cheap to put a new one in.
Thanks everyone!
Thanks everyone!
on
68 351 bronc
09-30-2011 05:57 PM
wavinwayne
03-07-2005 09:26 AM
