Grease gun hose for fuel pressure
How many of you guys are using grease gun hoses to relocate the fuel pressure sending unit?? I am wanting to see how many people are actually using them on here. I used some of them and they are leaking at the crimp fitting. Has anyone else been in this situation?? I'm never using them again and are going to keep the driven diesel hose in stock so this never happens again. I'm just looking for some consensus on those hoses.
I never had and wouldn't. Most off the shelf grease gun whips are a plastic not meant for fuel at all. The diesel will soften it and cause failure. I remember reading that on one of the packages, more than likely at my local Napa. Any hydraulic shop can make you a line to any specified length using a hose constructed of a fuel safe liner with stainless steel braided outer jacket. That's all I would use for fuel around a hot engine.
Well ok then,,, this situation is not a happy one btw. I hate to **** anyone off,, but I don't need a solution,,, of course a hydraulic shop can make them. Hell,,,, the freakn Oreillys I had deliver the wrong hoses,,,, could've made me one at their place. This whole situation has me in turmoil. I can just burn in hell for this.
Your scaring me with that comment,,,,,,,,,,,
And if you are going to continue doing this for a living you will again. The key is, don't make this mistake again. You admitted your mistake, nobody died and it sounds like the customer hasn't hired a hitman, yet.
Send the new hose with a gift card to use as bribe money for someone to put it on and there will be smiles all around.
A quality grease whip shouldn't be any different than a standard hydraulic hose, just higher PSI, think 5000 psi versus a standard 2500 psi.
I could see a cheapy Harbor Freight or Made in China grease whip kicking the bucket after a while due to diesel saturation.
It's all highly overkill as the fuel system will never generate more than 100-120 psi at most. A braided fuel injection hose would work.
With that said I have used grease whips on other 6.0 trucks, although IIRC my own truck has a gates hydraulic hose to relocate the sender.
Josh
Josh
Anthony with so much good that I have seen in the short time I have been here, what got me on here was reading when you went out of your way to New Orleans to help some one, this is a minor miss step and I know you wont have that happen again keep up the great things you do, and old Marine First Sgt. once told me that we are human and make mistakes that is why there are erasers on pencils. Have a great new year!!
