6.2 thirsty at idle?
Flew to Anchorage the day before thanksgiving and picked up my new F350 Supercab long bed. On the 360mi drive home she averaged 13.4 running in 4x4 probably half the time on some nasty roads the whole way. Next tank was 8.1 running all town with the longest stretch of highway being 2mi. This tank had many idle warm ups at temps around zero. Last tank came in at 7.5mpg with same type of driving and warm ups in the -10° and colder range. At home I park inside the shop but at work it takes a good 15-20 minutes to get things thawed out. I also hit the remote start when out and about at restaurants and what not. With the shock of the 7.5mpg last night I took her for a 100 mile road trip and found it to come in at 13.8 which is totally acceptable. Anyone else find the 6.2 to be thirsty at idle? In comparison my 7.3 diesel only looses about 2-3mpg from highway to town/idle. This 6.2 is dropping over 6mpg.
You are correct. The MPG indicator runs on constant averaging computations. If you just reset it, drove it at say 14mpg, then let it idle, it is averaging in the 0mpg idle time, and it will drop like a rock. If you haven't reset it in say like a month, the drop at idle would by far less noticable, if at all.
Denny
It will also make a huge difference in how you have you computer set up to read. You can set it to read at different intervals. So if you have it set to read and recalculate every 5 minutes a little idle time will make a huge difference. Where if it is set to recalculate every 30 minutes a little idle time will not have the same huge effect on the updated numbers.
LA_BigRed
28
12-03-2004 11:59 AM
