I own a 2000 Ford E-250 and the heat/A/C blow out at high and barely at any other speeds. I have replaced the blower motor resistor but still experiencing this issue.
Switch is the funky **** you turn to change speeds....You need to remove the dash Bezel to do this.....It is not easy without breaking parts....Do you live in a warm climate ? If the answer is NO then you need a heated garage....You will need to know how to disconnect the Headlight switch...( Ford Magic ) and ALOT of patience....I have done it a few times ....a couple of times it was not the switch......BUT you already changed the resisitor ...SO....it is either the switch or the harness ( Wiring)
