Did FORD equip power steering on 67-72 F600s ?
I have manual steering box on my 67 F600 (the supercab project)... and I would love to convert to power steering without having to change a bunch of other parts or adapt another type of box
Im wondering if Gemmer made power steering boxes for the f600s.. or another company that ford used ..in this era.. the later F600 PS box (73-79) has a different (much larger) shaft that wont work with the rest of the steering gear
Thank you
Thank you
Here you go, have fun building!
C7TZ-3504-S .. P/S Gear Box / Obsolete
1967/69 F500/750 with 5,000 - 5,500 - 6,000 & 7,000 lbs. front axle capacity.
Ditto 1970 before serial number G90,001.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
btw: You might give Marty a call at SoCal Truck Wrecking (you know where they are from your days as a LASD...323-587-3144) and see if he has anything.
Bill
You're awesome... I'll report back
Thank you
[QUOTE=fellro86;14965002]r
Thanks for the pics... they are really helpful... if I can ask you one last favor ... can you measure the diameter of the output shaft... the large one that goes to the steering arm... then I'll know if its a direct bolt up conversion where all I have to do is fan the high and lo pressure lines and equip the motor with an appropriate pump
Notme
Notme
