Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Did FORD equip power steering on 67-72 F600s ?
Old 01-04-2015, 01:04 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
Originally Posted by fellro86
I had put it in your other thread about the supercab conversion. It was right about 1 1/2".
You are right... thank you so much
Cam
Old 01-04-2015, 01:08 PM
fellro86's Avatar
fellro86
fellro86 is offline
I would think that if you run into too much trouble with the shaft size that you could get the steering arm as well.
Old 01-05-2015, 01:27 PM
Notmeofficer
Here you go, have fun building!
C7TZ-3504-S .. P/S Gear Box / Obsolete
1967/69 F500/750 with 5,000 - 5,500 - 6,000 & 7,000 lbs. front axle capacity.
Ditto 1970 before serial number G90,001.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
btw: You might give Marty a call at SoCal Truck Wrecking (you know where they are from your days as a LASD...323-587-3144) and see if he has anything.
Alas green sales had a manual box and had it mislabeled as power
and I got quoted two different prices, which didn't feel right... guess I'll rebuild my manual box and go on the search for a power steering one....
first quote ... first salesperson was 493... second..." better expert" was 650... there may have been a good explanation for the difference but it always feels shady when some person over the phone does that to you
The following users liked this post:
Old 01-05-2015, 01:44 PM
Notmeofficer
Bill
called marty, he's trying to find it
Old 01-26-2015, 10:08 AM
Notmeofficer
Hi All
Based upon Bill providing a factory oem number I did some more research and found that it crosses over to TRW/Ross steering gear
Ford C7TZ-3504-S
TRW /Ross HF54049... or HF54001 ( I think the first number is correct by looking at the picture)
SKU 40328
I still havent found one... the internet sources list them but when I call.. no luck.. so the hunt is on
I believe this is the picture of the box
The interchange numbers were here>>>>>
Heavy Duty Steering Gear Interchange
Thank you bill.. for the bright blue print!
The box looks like my later 73-79 box .. but I tried that one and it does not fit properly.. so I assume the later boxes are different
A&P_Tech
02-12-2018 12:04 PM
zombiefied 247
11-30-2012 12:55 PM
RobPStroker
08-13-2006 02:18 AM
80ford32778
02-15-2004 09:06 AM
Quick Reply: Did FORD equip power steering on 67-72 F600s ?
