1979 F100 Ranger Lariat RWD: can this be lifted with stock suspension?
I would like to lift the truck 2 or 3 inches, not much. I was told today that this will cause camber issues and I will need someone to bend the I beams because camber is not adjustable on these trucks.
Is this accurate? I cannot find lift kits specific to this truck in 2WD. Any help is appreciated.
Received 3,150 Likes
on
Drop brackets sounds easier, but the word "make" is scary. Why didnt you use the word "buy?" Also, this also means a weaker suspension system, right?
on
no matter the year, if you want to lift a 2 wheel with TTB front suspension, you are either going to have to bend the beams, or make drop brackets.
it is the same principle as a 4 wheel drive lift.
center drop bracket, and possible radius arm drop brackets.
the only real difference is the location of the center brackets. on a 4 wheel drive both sides mount in the middle of the truck.
on a 2 wheel setup, the mount on either side farther away from each other.
autofab makes a 3 inch kit for the 2wheel drive: 65-79 F100/150 2wd Truck 3 inch lift
on
Ok, so a friend has a race shop where he makes frames. He will probably help me if I ask him, but I want to know what I am asking him to do first. Is there any kind of instructions online I can point to to show him what I need done?
Is it safer to move the brackets or bend the I beams? Being new to these trucks, I am unfamiliar with the brackets or how they need to be moved (where they need to be relocated).
on
Helton79F100
08-25-2010 08:00 PM
77'F-150Mudder
06-02-2003 10:47 AM
TexasGuy001
11-07-2001 05:00 PM
