Bronco II Ford Bronco II
Suspension Help???
Old Mar 22, 2008 | 10:32 AM
broke77f100's Avatar
broke77f100
Suspension Help???
hey i just lifted the front of my 87 bronco ii using 77 F-100 coils. it gave me something like 3-4" of lift but now my alignment is off. Where can i get just the axle pivot drop bracket without buying a full lift kit? this is important because i cant be buying tires constantly.
Old Mar 22, 2008 | 01:30 PM
HappyJack's Avatar
HappyJack
Skyjacker has part numbers for the brackets. Center hinge brackets # CHBE30 and radius arm drop brackets # RABE30. You should use a drop pitman arm also # FA400. Are your shocks long enough? Might end up costing less to just by a low cost (BDS or Rough Country) kit.
