48 wiring to get it started /starter removal ?
hi
i have a 48 ford f1 all stock
sat in a field for a long time
wiring is shot and all switches shot
starter seized how do i remove it ? i have got all the bolts out that i can see but will not come out have i missed one
also
i think it is 6 volt battery ,how do i hot wire ,to try to start it
can i connect a 12v battery ?
richard
england
thanks for any help guys
also
richard
england
hi
also
richard
england
also
richard
england
To begin, if you have a 'stock' F1, it was equipped with either a flathead 6 or V8, both used the same starter and required the removal of only 2 bolts to remove the starter, they are indicated in the photo below.
The bolts do not need to be removed completely, simply backed out of the bell housing plate. If it's been sitting a long time, you may have to get the motor to turn some or beat and bang a bit to break it free from the flywheel.
To answer your other question, yes you can start it with a 12v and bypass all the old wiring. Make sure you have a coil compatible with 12v, you can hook a temporary 'hot' wire from the battery to the coil (don't hook up until ready to fire up) then ground the battery to the motor and jump the starter from the battery.
They fall apart if your not careful pulling it out. Have a nut handy to put on one of the bolts once you get it out. Also there should be a strap of sorts from one of the oil pan bolts that helps hold up the end when it's installed. I had a hard time getting brushes for mine at Napa and asked them to check for the 8N. Sure enough ,the same. By the way welcome to FTE. Lots of experienced folks here willing to help. Also the starters don't pull straight out, you have to kinda wiggle it a bit to get the thing out .
Elmo
12V Vintage Torque Starter | Dennis Carpenter Ford Restoration Parts
Or you can order a starter with the correct bendix.
JSPhotographers
18
01-29-2018 11:11 AM
DieselDrake
07-02-2012 04:11 PM
