4x4 Service Interval
I can drive my truck all day, and rarely go over 2000 rpm. It seems like you
could make a case that the plugs could last longer in and EB engine.
It is capable of producing much more torque per cubic inch then a normal
gas burner. Would using the engine at a high power setting, i.e. towing, cause a faster wear of plugs?
The higher the combustion pressure is the harder it is for a spark to jump the gap. A couple thousand volts will easily jump over an inch at atmospheric pressure, but it takes much more than that at several hundred psi.
I don't buy any turbo engines and I have easily taken plugs to over 100K several times. I just took them to 135K in my 5.4L work truck that does not see any easy use. It sees a lot of highway and quite a few days idling all day long with the A/C on high.
Probably is a waste of money if you don't DIY and you have no drivability problems because it will probably runya about $200 for someone else to change them. But for a DIYer or someone that is **** about their vehicles like me I want my plugs gapped to Fords latest specs so I would remove them and re-gap them down from .035 to .028-.030 because it is a free mod. Worst case scenario... if the plugs look bad it would only cost $28 to change them yourself. But to some people a vehicle is just transportation and to others it's a hobby/passion. Those people usually mod their vehicles to look and perform better than stock. Others just drive them and do required maintenance when it's required.
Sure it's highly unlikely, but you brought up worst case scenario.
About as likely as falling off your step stool while changing plugs and cracking your head open.
christcorp
04-01-2007 01:32 PM
