4x4 Service Interval
Old 12-28-2014, 10:26 AM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
Just replaced my plugs with 78,000 km's on the truck. Not sure what the deal is, but the turbo sounds louder now. Don't feel any increase in power or anything.
Old 12-28-2014, 10:57 AM
NASSTY's Avatar
NASSTY
NASSTY is offline
Originally Posted by Truckpilot1329
The EB runs at a low rpm, doesn't have an abnormally high compression ratio.
What exactly would cause it to go thru plugs faster then a non turbo engine?
Not sure but it seemed normal to me because I'm used to frequent plug changes on my V6 turbo Grand National.
I can drive my truck all day, and rarely go over 2000 rpm. It seems like you
could make a case that the plugs could last longer in and EB engine.
It is capable of producing much more torque per cubic inch then a normal
gas burner. Would using the engine at a high power setting, i.e. towing, cause a faster wear of plugs?
Maybe they won't be so hard on plugs now that they finally settled on a gap. On my early build 2011 the plugs came gapped at .035 Then I think at a later date they started gapping them at .032 On my 2014 they came gapped at .030 Now the latest TSB (14-0180) calls for .028 gap.
Old 12-29-2014, 10:39 AM
Turbo Dog's Avatar
Turbo Dog
Turbo Dog is offline
The higher the combustion pressure is the harder it is for a spark to jump the gap. A couple thousand volts will easily jump over an inch at atmospheric pressure, but it takes much more than that at several hundred psi.
I don't buy any turbo engines and I have easily taken plugs to over 100K several times. I just took them to 135K in my 5.4L work truck that does not see any easy use. It sees a lot of highway and quite a few days idling all day long with the A/C on high.
Old 01-02-2015, 03:22 PM
xr7gt390's Avatar
xr7gt390
xr7gt390 is offline
I asked about changing my plugs early and was told it was a waste of money unless there is a drive ability problem.
Old 01-02-2015, 07:41 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
Probably is a waste of money if you don't DIY and you have no drivability problems because it will probably runya about $200 for someone else to change them. But for a DIYer or someone that is **** about their vehicles like me I want my plugs gapped to Fords latest specs so I would remove them and re-gap them down from .035 to .028-.030 because it is a free mod. Worst case scenario... if the plugs look bad it would only cost $28 to change them yourself. But to some people a vehicle is just transportation and to others it's a hobby/passion. Those people usually mod their vehicles to look and perform better than stock. Others just drive them and do required maintenance when it's required.
Old 01-02-2015, 07:50 PM
Tom's Avatar
Tom
Tom is online now
Actually...worst case scenario would be weakening the metal on the ground strap and having it break off in your engine. That would set you back $10K.
Sure it's highly unlikely, but you brought up worst case scenario.
Old 01-02-2015, 08:14 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
About as likely as falling off your step stool while changing plugs and cracking your head open.
th67ss
10-23-2010 08:51 PM
christcorp
04-01-2007 01:32 PM
98 4.6 locked up
1997 - 2003 F150
07-25-2004 10:22 AM
Quick Reply: 4x4 Service Interval
