electric choke
electric choke
could my electric choke be the reason my truck "hesitates" or "stumbles". I just put a new edelbrock electric choke carb on. but did not connect wires to the electric choke since the old one was not connected either. starts fine, reverse fine stumbles when accelerates. should I take electric choke off or wire it, could this be the reason my truck stumbles???
If it's on the carb already non operational then yes it could be giving you the stumble.
For instance if the choke plate is closed, there is no way for it to open if the choke is not hooked up.
I would suggest as mentioned above that you learn about it and hook it up and adjust it correctly. It's a really nice feature on an engine.
In this case YouTube is your friend.
One video can teach what a hundred words in this thread cannot.
Start here
https://www.youtube.com/results?sear...electric+choke
Start here
Kyle Wood
01-28-2018 11:59 PM
