electric choke
Old 12-06-2014, 01:55 PM
79lownlong's Avatar
79lownlong
79lownlong is offline
electric choke
could my electric choke be the reason my truck "hesitates" or "stumbles". I just put a new edelbrock electric choke carb on. but did not connect wires to the electric choke since the old one was not connected either. starts fine, reverse fine stumbles when accelerates. should I take electric choke off or wire it, could this be the reason my truck stumbles???
Old 12-06-2014, 04:06 PM
jim collins's Avatar
jim collins
jim collins is offline
Why don't you just hook up the choke ? Black wire ground and the other to 12 volt.
It only works if it's needed if you set it up right.
Old 12-06-2014, 04:22 PM
turbohunter's Avatar
turbohunter
turbohunter is offline
If it's on the carb already non operational then yes it could be giving you the stumble.
For instance if the choke plate is closed, there is no way for it to open if the choke is not hooked up.
I would suggest as mentioned above that you learn about it and hook it up and adjust it correctly. It's a really nice feature on an engine.
In this case YouTube is your friend.
One video can teach what a hundred words in this thread cannot.
Start here
https://www.youtube.com/results?sear...electric+choke
Old 12-06-2014, 05:24 PM
79lownlong's Avatar
79lownlong
reason I did not hook up is because the old one wasn't and ran fine. I will hook it up and see if that helps
Old 12-06-2014, 05:28 PM
turbohunter
Totally understand.
The problem is now you have changed the system.
Prolly best to hook up and adjust as that's the way it's designed to work.
Good luck.
Kyle Wood
01-28-2018 11:59 PM
78bigunns
03-08-2009 12:56 PM
alconk
16
11-18-2008 10:41 AM
78RangerXLT
02-24-2003 10:07 PM
Quick Reply: electric choke
