where is Knock sensor
Old 07-18-2003, 05:51 PM
f1501988's Avatar
f1501988
f1501988 is offline
I have a 1988 302 F150 2wd. I cannot find a diagram in any of my manuals that shows me where the knock sensor is or somtimes called the ESC sensor. I have a slight ping on ecceleration. This ping goes away when I increase octane. I also have a code 32 on the continuous memory test. I get a system ok on the KOER test and I get the same on the KOEO test. The symtoms are hard starting and stall when cold first start of the day. After intial start I don't have a problem. It also seems to occur when it is hot outside and not during the winter. The AC on or off dosen't effect it. It also dosen't change with tank selection.
Old 07-18-2003, 10:36 PM
Cloim's Avatar
Cloim
Cloim is offline
autozone.com has a component location lookup.
It says "UNDER HOOD, CENTER, UPPER ENGINE AREA". Not very informative, but sometimes it gives enough info to allow you to find what your looking for.
On my '86 the knock sensor is located on the lower intake manifold, on the drivers side. There is also an air charge temp sensor near it.
Yours may vary.
Old 07-20-2003, 09:47 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
Diesel_Dummy _ is offline
it is located on the rear of the motor just behind the intake manifold on the right side
Heavy Duty f250
1999 to 2016 Super Duty
34
05-30-2011 11:09 AM
74f250-466scj
44
04-30-2010 07:45 PM
Explorer Freak
03-29-2010 12:34 PM
rc2004
02-02-2010 11:59 AM
kern
Aerostar
08-29-2005 11:12 AM
Quick Reply: where is Knock sensor
