Ecoboost power lose
Ecoboost power lose
Does anybody have experience with 2013 Ecoboost losing power. Starts missing and shuttering like it's running out of gas. This truck has 100K miles with no trouble. If wasn't built into the fuel pump module, I'd replace the filter. Checked TSB's no matches there.
All comments welcome
I wish I had an answer for you.
What are the symptoms?
Took it to the Dealer. Tech said the truck has a learned strategy for plug wear and you should reset the system to allow for new plugs. Does this make sense to anybody? I oversee a fleet of 35 trucks, mostly 3/4 ton and up. Has anyone had any dealings with higher mileage Ecoboosts?
So that explanation doesn't surprise me that much.
Thanks Conger. It seems to be ok now.
Personal note; I worked as a Ford tech at Dub Shaw Ford in Ft. Worth beginning in1977, stayed with Ford until 1998(13years Service Manager). I own 2000 F-150 XLT,
2005 Crown Vic Sport Pac, 2013 F-150 XLT (5.0L). So I've seen a lot of changes. If I can help anybody with the older equipment don't hesitate to ask.
thegreatgate
2004 - 2008 F150
08-02-2014 05:48 PM
