Ecoboost power lose
Old 12-05-2014, 01:22 PM
oilfieldanchor's Avatar
oilfieldanchor
oilfieldanchor is offline
Ecoboost power lose
Does anybody have experience with 2013 Ecoboost losing power. Starts missing and shuttering like it's running out of gas. This truck has 100K miles with no trouble. If wasn't built into the fuel pump module, I'd replace the filter. Checked TSB's no matches there.
All comments welcome
Old 12-06-2014, 07:41 AM
NASSTY's Avatar
NASSTY
NASSTY is offline
A lot of people have reported their spark plugs were shot at 35k-40k miles. If yours have never been replaced I'd put some new Motorcraft SP534's in gapped at .030 They are cheap and easy to change. I paid $3.99 each at Orielly's
Old 12-06-2014, 11:09 AM
Greg B's Avatar
Greg B
Greg B is offline
I second what NASSTY said plus I'd also change the coil boots for starters. If that doesn't work, I'd get a scan to see what other codes there are and work from there.
Old 12-07-2014, 07:50 AM
conger's Avatar
conger
conger is offline
That's a lot of miles for one year. That's impressive. You must be, just about living in your truck to rack up 100k in one year.
I wish I had an answer for you.
What are the symptoms?
Old 12-08-2014, 12:03 AM
PrinceValium's Avatar
PrinceValium
PrinceValium is offline
Nasty...Maku was recommending to gap them to 0.028 in his latest video.
Old 12-08-2014, 02:48 AM
NASSTY's Avatar
NASSTY
NASSTY is offline
It won't matter much on a stock truck. .028 would be better on a tuned truck. Either way .030 is quit a bit smaller gap than my old 2011 came with from the factory.
Old 12-08-2014, 09:15 AM
oilfieldanchor
Spark plugs are new, 6 weeks ago. A Ford tech friend told me the plugs were failing a little prematurely as a result of the lean burn the Ecoboost has.
Old 12-09-2014, 08:49 AM
oilfieldanchor
Took it to the Dealer. Tech said the truck has a learned strategy for plug wear and you should reset the system to allow for new plugs. Does this make sense to anybody? I oversee a fleet of 35 trucks, mostly 3/4 ton and up. Has anyone had any dealings with higher mileage Ecoboosts?
Old 12-09-2014, 09:45 AM
conger's Avatar
conger
conger is offline
The ECU system in these new trucks control many different aspects of engine behaviour. Another example could be how the BMS controls the charging field in the alternator to manage battery charging to extend life and save fuel.
So that explanation doesn't surprise me that much.
Old 12-09-2014, 10:04 AM
oilfieldanchor
Thanks Conger. It seems to be ok now.
Personal note; I worked as a Ford tech at Dub Shaw Ford in Ft. Worth beginning in1977, stayed with Ford until 1998(13years Service Manager). I own 2000 F-150 XLT,
2005 Crown Vic Sport Pac, 2013 F-150 XLT (5.0L). So I've seen a lot of changes. If I can help anybody with the older equipment don't hesitate to ask.
Old 12-09-2014, 10:54 AM
conger's Avatar
conger
conger is offline
These new trucks are quite something. I have to say that I have not regretted trading in my old SD for the 2013 F150 last year. If I was doing it over, I'd buy another in a heart beat.
Old 12-09-2014, 03:09 PM
huntnrig's Avatar
huntnrig
huntnrig is offline
Stretched timing chains will also display the same missing/hesitation and power loss symptoms you describe but it's usually accompanied by a loud rattling noise on cold starts. At your mileage the chain could be stretched.
tylerz71
2004 - 2008 F150
11-19-2015 07:31 AM
hannibal0268
1997-2006 Expedition & Navigator
01-06-2014 01:45 PM
Alean Merker
2004 - 2008 F150
01-17-2013 10:39 AM
lylino
Escape & Escape Hybrid
07-23-2009 11:01 PM
Quick Reply: Ecoboost power lose
